output passes to separate folders
Yes all EXR options are settable through maxscript, even more than through the UI.
The reason why this sometimes works and sometimes not is probably because you need to actually write a file to disk first for the settings to be locked in. This is how max bitmap IO works unfortunately.
Try this, it’s a basic script I wrote a while back. This will allow you to set the EXR settings for 3ds max file output and render elements. Doesn’t work for VRay outputs yet. Also there’s no way that I know to read out the settings from an existing render element, so there’s no feedback on what the elements are currently set to.
It assumes you already have your output set to the correct location, this doesn’t change the file’s location, only the EXR settings!
try destroyDialog dlgSetEXRSettings
	catch()
aElems = #()
append aElems "Max FileOut"
objRmgr = maxOps.GetCurRenderElementMgr()
iElemC = objRmgr.NumRenderElements()
for n = 0 to (iElemC-1) do
	sElem = (objRmgr.getrenderelement n).elementName
	append aElems sElem
rollout dlgSetEXRSettings "SetExrSettings_v001_rh" width:368 height:600
	MultiListBox mlbOut "EXR Outputs" items:aElems pos:[16,16] width:216 height:37
	dropDownList ddlForm "Format" items:#("Float32", "Float16", "Int32") selection:2 pos:[240,32] width:112 height:40
	button btnSet "Set Selected" pos:[56,536] width:128 height:32
	dropDownList ddlType "Type" items:#("RGBA", "RGB", "Mono") selection:2 pos:[240,80] width:112 height:40
	dropDownList ddlComp "Compression" items:#("None", "RLE", "ZIPS","ZIP","PIZ","PXR24","B44","B44A") selection:3 pos:[240,128] width:112 height:40
	dropDownList ddlStor "Storage Type" items:#("Scanlines","Tiles") selection:1 pos:[240,176] width:112 height:40
	dropDownList ddlReg "Image Region" items:#("Full","Region") selection:2 pos:[240,224] width:112 height:40
	on btnSet pressed do
		bDlg = renderSceneDialog.isOpen()
		renderSceneDialog.close()
		iForm = ddlForm.selection - 1
		iType  = ddlType.selection - 1
		iComp = ddlComp.selection - 1
		if (ddlStor.selection - 1) == 0 then bStor = true else bStor = false
		if (ddlReg.selection - 1) == 0 then bReg = false else bReg = true
		aSel = (mlbOut.selection as array)
		if aSel.count != 0 do
			for n in aSel do
				fopenexr.setLayerOutputFormat 0 iForm
				fopenexr.setLayerOutputType 0 iType
				fopenexr.setCompression iComp
				fopenexr.setSaveScanline bStor
				fopenexr.setSaveRegion bReg
				fopenexr.setAutoAddRenderElements false  -- !!!!
				if n == 1 then
					rendOutputFilename = rendOutputFilename -- not sure if it actually updates like this
				else
					i = n-2
					elemI = objRmgr.getRenderElement i
					sElem = objRmgr.getRenderElementFilename i
					sElemPath = getFilenamePath sElem
					sElemNew = sElemPath + (i as string) + "_DELETEME" + ".exr"
					makeDir sElemPath
					bmTemp = bitmap 1 1 filename:sElemNew gamma:1.0
					save bmTemp
					elemI.bitmap = bmTemp
					objRmgr.SetRenderElementFilename i sElem
					close bmTemp
					deleteFile sElemNew
		if bDlg do renderSceneDialog.open()
createDialog dlgSetEXRSettings
Ah - it might be missing from the 2012 docs perhaps? There wasn’t anything available there when I looked at it originally. Must have a run through your script Rens - I never put in the part about writing a temp bitmap into our fileout bits, lazy on my behalf. How’s stuttgart treating you?
It think the 2012 docs has them, not the 2011 ones, I’m not sure if they updated them later on or not though. Yeah it’s a very peculiar way to go about it, but if it works it works. There isn’t really anything in the docs about how to make the settings sticky though.
Stuttgart is good, thanks, how are things in Dublin?
Busy and constantly evolving! Two friends of mine are both on to their second feature films now so it’s looking like some good RnD and then into pre-production early next year. Lots to work on and plenty of software things changing at the minute too!
+1 for this - day,month,year, & time tokens would be what I would use. Oh and the camera/view name? Is that even possible? Is it possible with max script?
At that point I could just run through my cameras firing off renders to the farm and not worry about renaming new versions and also not having to change the output name as I go through the list.
[date %y%m%d]_[%camera]_[time %h%m%s].exr
::drool::
+1
Its is useful.
About the original request of this topic: can someone confirm that it is still impossible even with vray3 to output render elements in separated folder when using VFB?
It would make my life so much easier with my colleagues :smile:
Unfortunately it is not implemented yet. I will make a note to the relevant request in our system.
Related topic : http://forums.chaosgroup.com/showthread.php?78613-Vray-VFB-with-standard-renderelements
Actually, I find really astonishing how VRay is powerfull and can be so tricky on saving our render files !
Isn’t this feature implemented yet?
Only in V-Ray for Maya.
Since there are very many requests, I need your help.
Before 3.5 will be out, will this feature be implemented?
It’s really frustrating when someone doesn’t remember to uncheck VFB and you lose all elements :frowning:
+1 -- would love to see Render Elements saved into named folders (based on name of element). Would make life with After Effects much easier when using non-sequential frames.
+1 for this!
For now if you use after effects you absolutely need the immigration script.
If only windows explorer and max would support stacking sequential frames in the browser like Houdini, Nuke and even the free open source Natron do.
