Output Path Error - Back Burner
Hi
What is up when Back Burner errors and says - ‘Output Path’ ? Then lists an output path which is perfectly valid from that machine using UNC paths.
N
I get that sometimes too…not sure why. I know my UNC paths are all correct too.
BB sometimes gives that message when there is not enought space on the HDD or some machines can’t see it for some reason
zoran
Thanks for your reply.
I have checked and the UNC paths are correct and accessible, also the HD is sufficiently empty to deal with the outputted files.
There are 5 other machines with exactly the same setup which are all running.
BB could teach the Bermuda Triangle something when it comes to things being unexplained for no good reason what so ever !
