This is not new but old bug… which is still in final I am facing.
When resizing output size, C4D quit. it happen with most of files.
To making it easier… video uploaded (resizing.mp4) and bug report is here.
Thanks.
p.s.
there was one more, that I forgot file in office.
When placing .png texture file in reflection slot… it was quitting, with JPG it was fine.
I can update you on this on sunday… when back in office.
Hi Imran, Maybe you should be using the new feature to limit the IR output. Just set your desired max output resolution and the IR window will stick to it. You can make the final render output any size you like and this will have no effect for IR.
It is set to 0 and it is not new old issue… and I think I sent you that video also in beta 2.
I know this crash and most of time I save the file but some time…sudden death and do setting again.
I am sure you can also get this crash… try one scene, IR few time, render it and change size… u will get that crash.
The maximum output resolution was added in V3, I would suggest not setting it to 0 unless you want the IR to be the same size as your final render. It defeats the purpose of this feature. If you want a small IR window to work with yet maintaining a huge final output res, then you will need to input a size ie: 500, 800 etc. Whatever works best for your screen.
I did try changing the final output whilst the IR was running but had no crash here. In fact, nothing happened until I refreshed it. Hope that helps.
