Is it possible to create an overcast sky effect in Corona for C4D without using an HDR? There seems to be a setting in Max that I don’t see in C4D. Any advice would be greatly appreciated. Thanks.
Where did you dig up that screen? CoronaSky in 3ds max looks like in my attachment. There’s no explicit overcast control in it, but it’s quite possible to achieve desired effect by increasing turbidity (usually i set it to 7-8 for overcast sky) and decreasing sun intensity to 0-0,1. Additionally you may want to increase sun size and adjust white balance.
Romullus - thanks for the reply and tips. I’ll give them a try. I found that image under an Evermotion tutorial from 2013 here: https://evermotion.org/tutorials/show/8334/making-of-small-living-room. Perhaps that was a build from the past. Thanks again for the advice.
