Swapped the CPU fan around to this position (Pushing up).
The results are both around 7-13.5degC lower than before the post below.
I know the fan is probably sucking in hotter air in this position next to the GPU but this is as good as I can do until I get thermal paste and the rest of the upgrade stuff.
Just thought I’d follow up on results. And it worked out well. Defiantly was due to the old heat-sink not working correctly. I think the cooling plate may have been faulty out of the factory. Either that or the paste wasn’t properly applied.
Anyway the results with the new H110 from Corsair. I used the benchmark scene found on this forum.
Stock @ 3.2Ghz (CPU: Max avg. temp 45dC)
Corona Renderer Alpha 4 benchmark scene
Living room 100 passes
Intel(R) Core™ i7 CPU 965 @ 3.20GHz
Time: 0:6:48, Rays/s: 3,114,342
1min 30sec shaved of which isn’t to shabby. The temps are much much better. The last OC’d @ 4.160Ghz had been OC’d for two days after the previous test at 4.0Ghz. I just wanted to see if was stable enough to post.
IMPORTANT:
If you do happen to purchase the H110 DO NOT USE a screwdriver like a youtuber with a million + subscribers tells you. You’ll end up f******* up the backplate because it’s only made for hand tightening. I got one sent to me as soon as I emailed them. I’m not fortunate to have an access panel to the back of the CPU so it means having to rip out the MB once again.. noice!!!
OC @ 4.16GHz (75degC).jpg Shows the temps and CPU stress test pass from the Intel Processer Diagnostic tool.
And some pics of the new setup (some show the old cooler).
New Noctua NF-F12 IndustrialPPC 3000RPM PWM 120mm High Performance Fans
970GTX GPU
Notice the Silica Gel Pouches, these soak up any moisture that may be in your case.
