I have just started using V-ray,I use it with Max 2010. When I put a sky or colour in to Vray enviroment it does not overide Max’s one.
Yes, its an override. Vray uses what ever is in this slot/colour for the environment (skylight) instead of whats in the max environment slot/colour.
But will still see max’s environment slot/colour in the background of your rendered image.
So how do I make it render what is it the Vray slot?
instance the vray env slot to the max env slot and it will be the same
