OVERLAP without compositing?
I need to render overlapped object,
for ex. a sphere fading to an half one, can i do this?
I’m using the visibility control
It’s a simple effect but it do not work (flickering)
I’m using GI, reflection and so…
I turned the secondary bias to 0.1…
I’d like to render it in one pass, without compositing, 'cause many object are interpenatring,
all the objects are coming from a step file, so I can’t use the slice modifier.
ANY IDEAS?
you might be better off using an animated opacity map of some sort
