I’m trying to make a quick script to add the currently selected object/objects to the exclude list for the Override Mtl in the render settings and am not having any luck. A little background… I’m working on a revit file with 100’s of objects that I’m currently redoing the materials on. Initially I set up the scene with an override material to preview progress. As I update the material on an object want to just click a toolar button and have that object added to the exclude list rather than having to open the exclude list and find that particular object.
Here’s what I have so far:
vr=renderers.current
ExclList=vr.excludeListOverrideMtl
Geo = for o in selection where superClassOf o == geometryClass collect o
appendIfUnique ExclList Geo
Seems straightforward but nothing gets added to the list. I have a feeling it’s something simple I’m overlooking. Any help is much appreciated.
afaik you can’t directly append to the override list.
You need to check if your object is ever into, build you own list, and finnally set your own list as vr.excludeListOverrideMtl
Exactly right. Simply replacing the append with a findItem and a full replace did the trick. Thank you.
If anyone’s interested here’s my somewhat finished script. It works just like I need it to, select an object and click on the toolbar to add it to the exclusion list. I did have a small problem where deleted objects that were already excluded were still in the list as “undefined” so there’s a small loop to clean those out. I’m planning on popping up a little message box confirming what was added or skipped so there’s a few extra lines in there that aren’t strictly necessary but don’t get in the way. Thanks again for the help - huge timesaver.
macroScript AddToOverrideExcl category:"dPict Tools" tooltip:"Add to Override Exclude List"(
newExclList= vr.excludeListOverrideMtl
--cleanup existing exclusion list for undefined
for i = newExclList.count to 1 by -1 do
if newExclList[i] ==undefined then
deleteItem newExclList i
if selection.count>0 then
For o in selection where superClassOf o == geometryClass do
if (findItem newExclList o)==0 then
append newExclList o
vr.excludeListOverrideMtl = newExclList
else
messageBox "Nothing Selected"
