Override material & render mask bug
Rendering using a render mask will include the objects with override material applied even though they are not included in the render mask list.
Seems to work fine here on a simple scene ? Can you share some more details or a sample scene?
Yavor
So, the reason I used a overidematerial was to control the shadow darkness. I had a vraycolor in the shadow slot. Not sure if this makes a difference to your test scene.
If your test still proves to work as expected I can send you the scene. Can you remind me of the email address to send it to. Thanks.
If it is a small/test scene - you can share it here directly. Otherwise you can submit it to our support (https://support.chaos.com/hc/en-us/requests/new).
