Overriding environment texture
Is it possible to set a background texture via an environment override in Solaris? I’ve been poking around the Render Settings LOP, but there doesn’t seem to be a way to hook up something like the Environment Node in the OUT context.
Using Houdini 19.0.498 and vray 5.20.20
Thanks,
Chris
There are environment settings at the dome light.
I’m unable to find any environment settings in the vray section of the dome light vop. Can you point me to the right tab, or the parm name? Perhaps I have an older build without this option (I’m on vray 5.20.20).
1. Try more recent build.
2. UI in Solaris is not updated automatically - you have to create new dome light.
Yes, I am creating a new dome light node to test. I’ll see about getting a later build.
