ozanb
February 14, 2010, 3:26pm
1
2010 WORKS
evilwarrobot
architecture
glass, liquid and ice
artworks (mesh is a 3rd party model that I modified)
[kitchenware (model by Mcneel)
Dragon May 2010 (3rd party model)
Grass Scene May 2010 (Inspiration: Micha)
Earth May 2010
Moon April-May 2010 (Inspiration: Matthias)
2011 WORKS
logo for our golden retriever
golden pieces
Nintendo WII Console (Model by Claas)
All criticism including negative ones are welcome
ozanb
February 15, 2010, 10:26pm
2
Re: Ozan B. Render and modeling works 2009-2010
ozanb
February 15, 2010, 10:30pm
3
ozanb
March 4, 2010, 12:31pm
4
milk shake, special thanks master gjis
so either my renders are not good enough, or people do not bother clicking small versions of renders
any critique or comments please
ozanb
March 19, 2010, 7:20pm
5
Re: Ozan B. Render and modeling works 2009-2010 [update mechanized rhino]
ozanb
March 19, 2010, 11:23pm
6
ozanb
March 19, 2010, 11:24pm
7
Re: Ozan B. Render and modeling works 2009-2010 [big update displacement]
original is 1600x1200 with displacement cropped and resized to 640, took 2 hours to render
if you like it I may share the uncropped version too
Re: Ozan B. Render and modeling works 2009-2010 [big update 3 mechanized rhino]
AWesom materials !!!best metal i ever seen on this forum!
ozanb
March 21, 2010, 1:13pm
9
thanks for the comments, nobody else commented yet
I post some updated displacement material instead bump which took 2 hours to render
still my color management is not cool and my renders are too dark so I brightened a bit with photoshop
frip51
March 23, 2010, 9:19pm
10
Re: Ozan B. Render and modeling works 2009-2010 [update 4 rhino with displacement]
Ozan,
that’s some brilliant materials mate
Congratulations!
How did you map this onto the Rhino head?
ozanb
March 23, 2010, 10:09pm
11
Matthias:
Ozan,
Congratulations!
if you ask mapping type I just applied material
the main trick with mapping is if your surface is modeled smootly the mapping also turns out fine
and the material is very detailed
if you look closely there are 6 parts in the head
maybe I can join the 2 parts in the front covering the mouth
I may also remove the blade from the long horn
ozanb
April 2, 2010, 1:50pm
12
thanks to matthias for inspiration
teofas
April 5, 2010, 2:48am
13
Re: Ozan B. Render and modeling works 2009-2010 [update moon scene]
ozanb: nice rino bro, those materials are great, but other renders looks little flat to me, maybe cause of the lightning you use, but in all this are nice works, ill be watching your updates bro, i can see that with each render you improve ;D
zuper
May 14, 2010, 8:31am
14
Re: Ozan B. Render and Modeling Works [May update:Moon scene]
very very :o :o :o nice
Did you use material in the glass of milk shake?
Like the effect of that…
Congrats
ozanb
May 14, 2010, 8:56am
15
thanks teofas
Yes I tried to give an etched glass/dirt effect, so over the glass material I added some bump transparency map etc. for realism
also for glass type objects you need a smooth model especially in the corners
Thanks for the comment
zuper
May 14, 2010, 9:02am
16
great… ;D
This is not a very easy material to achive quickly…what layers did you use in the material?
best,
ozanb
May 14, 2010, 9:27am
17
Earth Scene Material and Lighting Setup, Render and Watermark: 40 minutes
The glass was Refraction, diffuse, reflection with some bitmaps but the milk material and lighting is also important
Re: Ozan B. Rendering Works [Update:Moon, Earth & Dragon]
Nice renders ozan, that moon its intresting :), does materials are great.
ozanb
May 26, 2010, 8:25am
20
Thanks daves, you people keep commenting and I keep posting new scenes
My grass scene
Inspiration: Micha
