Packed Alembics not assigning materials anymore
I have a scene I upgraded from Houdini 17.5/vray 4.5 to Houdini 18/vray 5 bit by bit with mostly success - however some parts of my scene stopped working, I discovered the changed behaviors and adjusted - one issue Im having however is that it seems like perhaps the way shop_materialpath is read from packed alembics has changed as a bunch of chracters I have now render white that didnt in the previous version. Can anyone point me to a rundown of how I should be doing material assignments (currently writing the shop_material attribute to disk on a packed disk sequence and that WAS working), unsure what has changed or how I should be reading alembics back through.
Cheers
Ben
edit: I am forcing materials * also.
Yeh it seems that forced materials is having no effect.
I have mesh β†’ material node (shop_materialpath) β†’ render to alembic β†’ Alembic SOP set to packed geo β†’ render, forcing all materials β†’ No materials visible.
Found this - promoted my materials up to top /mat level and that worked -but - I can’t afford to do that across my massive scene - not to mention the visual mess of it all.
Im on VRay for Houdini 11249 VRay Core 5.00.50 - has this been fixed since? Or is this something else?
I figured this out - I was using shading networks reconstructed from Maya in Houdini - they all contained the VRayNodeMtlSingleBRDF inside the material builder - this would prevent the materials on the packed objects from rendering - as soon as I got rid of that node, my shaders returned.
@bender83 , thanks for posting the solution, could be handy in the future.
Hello @bender83 , can you share a simple scene, so I can check it my side ?
I will send via pipeline from Zoic Studios as soon as I get the chance!
