"Paintable" Groundcover
When working in Revit with topography the groundcover such as pebbles or dandelion only show on the elevation that they are placed on so they half clip out of the plane of grass or whatever material the topo surface is assigned. I imagine there could be a way to select a groundcover such as the dandelion or even add other flowers that you can choose a size and density of a “brush” of the ground cover and paint a topo surface or a floor. An example I am imagining is a house in a meadow with rolling hills and flowers covering them. Maybe part of it would be adding additional grass types but it would be great to be able to more easily control where and how the groundcovers interact with different topography and floor planes. And I guess this “paint” idea can apply to other items within Enscape as well such as bushes or trees. Also as I touched on a possibility of changing the density of ground covers instead of currently needing to place several on top of each other and offsetting them slightly. Anyway thank you for all the hard work and I look forward to future updates!!
Thank you @Tonyv5498 , that has definitely been requested before a couple of times in a similar fashion. You may actually want to follow the corresponding tutorial from a Forum user here. If you like, I can still forward your request to our developers though if you would like to see this provided natively by Enscape. Thanks a lot in advance!
