So, I’m having a strange issue with generating Panos in Enscape. My Enscape window shows a happy well lit exterior, but when I generate a pano the end result is a dark image…like the GI was turned off. Any way to fix this?
Try starting your panorama when looking at a dark spot or the ground: the auto-exposure is taken from where you start looking and it makes no difference to where the actual render starts generating from.
That’s not it…When open the file on someone else machine it works fine. Not sure if my profile is corrupt, but it seems not to work on machines I log into.
So I think I figured it out…Not sure why this happens, but when I delete the sub folders in the Enscape folder under Documents, I must clear something out.
