I need help for making a 180° panorama for a client. I know how can i do for 360 but is it possible to do it at 180 ?
Thanks in advance
Just use cropping tool. Either directly in VFB (faster rendering) or in post process (more control). Unless you want to change projection too.
Thanks Romullus,
Cropping tool with 360 CoronaCameraMod ? I’don’t understand very good, sorry.
And Projection type Cylindrical doesn’t good for 180 ?
Yes, cropping in 3ds max works well even with 360 panoramas, you just won’t have visual representation in viewports.
As for projection, you can choose between spherical or cylindrical in CoronaCamMod - there’s no problem, even if you don’t need full 360. Only if you need other projection types, like rectilinear, you have to convert to that outside of 3ds max.
