Panorama exporter compatibility with vray
I’m trying to create a panorama using the panorama exporter in max 6. Works fine with Vray, but when I choose to export it to QTVR from the viewer the option is greyed out. I have Quicktime Pro on my pc, so I’m starting to think that it may be a vray compatibility problem.
Can anyone let me know if this is a vray problem?
Cheers!
Zap
don’t waste time , use this pano tour generator:
we are working on a extended version with hdr-like support:
i think it will do what you want and is maybe better than the max6 exporter (don’t have 6)
Doesn’t seem to work.
So back to my original question :lol: … is this a known problem with vray or am I missing a particular setting?
Hi Zapcat
I have been using the pano exporter in Max successfully with VRay.
Is the export to QTVR greyed out as soon as your rendering has finished?
The only time I have seen the QTVR option greyed out is when you open in the ‘viewer’ a render that was exported previously as a spherical map and then try to re-export as a QTVR.
Unfortunately Panonodes do feature in max 6 so this script isn’t much use to me. :frowning:
Any other ideas? I’m getting really desperate…
the script render it’s own spherical panoramas ..so what doesn’t work for you?
http://www.cgtechniques.com/goodies/panotour/help/panotour\_viewlet\_swf.html
Okay, I figured out what I was doing wrong and now have a decent panorama and HTML page. Sorry about saying it didn’t work. :sweat_smile:
I want to add the panorama to a multimedia cd so I’ll have a go at adding it.
Anyway, thanks for pointing me in the right direction.
:lol:
Zap
