Panorama flash animation
Hi ASGVIS! im kinda new in here, just want to ask how to make a panoramic image using vray for sketchup. I’ve tried it in sketchup using the plugin CubePanoOut. But this can only create a sketchup output, not a vray rendered output. Has anyone ever tried it? Please share some tips ASGVIS gurus. Thanks a lot in advance. hope you could help out. ;D
Re: Panorama flash animation
Go to Vray ‘Options’
Then ‘Camera’
And check the drop down menu for ‘Type’
There are difference choices for rendering camera types: Spherical.
Hope that helps.
Rob
Also, you will need another program to convert the sphereical image into the MOV animation file you sound like you are looking for. I’ve used this program (not free) but is fantastic and has many more options that CubicPanout. http://gardengnomesoftware.com/pano2vr.php
Thanks for your kind response guys! I tried the spherical camera but i don’t know if it will work with pano2vr. because my output only covered the view on my rendered view not the 360 degree image. ;D.. anyway thanks guys! hope we could work on this. If you have any tips please share them… really need this. thanks a lot ASGVIS for all the help! really appreciate it.. ;D
Got it guys! CubePanoOut did the trick! thanks a lot! hehe… ASGVIS Rocks!!! ;D
I have one more problem. when stitching the images, they do not match with each other.
