I need to render out a panorama of a scene for a client, but I cant find where to do this…The Render Panorama under utilities won;t let me use a vray camera.
Thanx
Thanx
ya its been mentioned several times. You have to use standard cameras for now. ![]()
Today must be “No Search” day or something… sheesh :roll:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=19344&highlight=panorama
You could always keyframe the physcam to rotate and then stitch it just like real camera.
Grrrrrrr ![]()
I am currently also fighting with this one.
Here is my best result, so far:
(*) Create a Standard Camera.
(*) Don’t touch any of your lights (VRaySun, or VRayLights) which are set to be OK for your VRayPhyCam.
(*) Just lower the Color Mapping multiplier until you get the same result.
Several tests will bring it to your appeal.
(*) Use the VRay::Camera Override options and render a Spherical Camera with FOV = 360.
(*) DONE !
So far the MAIN disadvantage is:
(*) Keep in mind the WB (White Balance) corrections in your VRayPhyCam. You might need to do those in post in order to get the same result.
(*) Lack of vignetting.
nikki Candelero
Well you’d hardly want vignetting in a spherical panorama anyway so not that much of a problem ![]()
nikki, i developed a solution for this. Let me know if you want to have a look at it
Hi Jacks02,
i would be interested in your solution too, if you would be kind enough to share it.
Vivek
Sure Chris…
But mind i need a 6 side panorama, not a 4 side… a whole 360 degrees one.
Let me know.
nikki Candelero
ah right, im still working on that one ![]()
