Hello Chaos Support Team,
I would like to report several issues and feature requests related to Enscape and Chaos Cloud, particularly regarding panorama rendering, sharing, workflow, and performance.
We are an architectural/design company that has recently moved our visualization workflow from Lumion to Enscape, and we currently have 13 Enscape licenses across our team.
There are several workflow and functionality issues that we have encountered, particularly when working with Revit and 360° panoramas.
We would appreciate it if the Chaos team could review the following points, as resolving them would have a significant impact on our team’s day-to-day workflow.
1. Panorama Ordering in Chaos Cloud
Currently, there does not seem to be an option to manually arrange/order panorama images in Chaos Cloud.
For example, platforms such as Kuula allow users to organize the order of 360° panoramas, which makes it much easier to navigate through a project in the intended sequence.
It would be very useful to have an option to:
Manually reorder panoramas.
Set the starting panorama.
Control the navigation sequence between 360° images.
2. Folder Thumbnails & Sharing Preview
Chaos Cloud displays a thumbnail for a folder/project inside the Cloud interface, but this thumbnail does not appear correctly when the project is shared externally.
For example, when sharing a Chaos Cloud project through WhatsApp, the shared link does not show:
The project’s/folder’s thumbnail as a preview image.
The folder/project name correctly in the link preview.
It would be useful if the shared link generated a proper preview containing:
Project/folder thumbnail
Project/folder name
Appropriate description/title
Similar to how platforms such as Kuula generate link previews.
3. Enscape – Direct Upload to Chaos Cloud Fails After Rendering
This is one of the most important issues we are experiencing.
When rendering from Enscape and exporting/uploading directly to Chaos Cloud, the upload sometimes fails and displays an “Unable to export” error.
As a workaround, we have to manually upload the rendered files again after the rendering is completed.
Ideally, the workflow should be:
Enscape → Render → Automatically upload to Chaos Cloud
without requiring the user to manually upload the files again.
Please investigate whether this is related to the Enscape-to-Cloud integration, especially for panorama renders.
4. Panorama Output Settings in Enscape
When rendering a panorama/360° image, the Output settings in Enscape appear to have very limited control.
Currently, the panorama output mainly provides a resolution option, while several other settings in the Output tab do not seem to affect the final panorama.
It would be useful to have dedicated panorama output settings, including controls for:
Resolution
Image quality
Compression
File format
Other relevant panorama-specific output parameters
5. Slow Loading When Switching Between 360° Images in Chaos Cloud
Viewing 360° images in Chaos Cloud can be relatively slow.
When switching from one panorama to another, each image appears to require a loading period before it becomes visible.
Compared with platforms such as Kuula, where switching between 360° images feels much faster and more seamless, the current experience can feel slow when reviewing multiple panoramas.
It would be helpful to improve this through:
Faster panorama loading
Preloading the next/previous panorama
Better caching
Progressive loading
Optimized 360° image delivery
6. Enscape Rendering Stops When Editing the Revit Model
This is another important Enscape/Revit workflow issue.
Sometimes, while an Enscape rendering is in progress, if we make a change to the Revit model, the rendering stops or gets interrupted.
For example:
Start rendering → Make a change in Revit → Rendering stops
This can be particularly problematic when working on large projects or when the rendering takes a significant amount of time.
It would be useful if Enscape could either:
Continue the current render independently from subsequent Revit changes, or
Provide a more robust rendering process that is not interrupted by unrelated model modifications.
7. Enscape Visual Settings – Additional Rendering Controls
The Enscape visual settings currently feel more limited compared with some of the visualization tools we previously used in Lumion.
For example, Lumion provides additional visual controls and effects such as:
Global Illumination
Hyperlight
Sharpening
Advanced Color Correction
Additional image enhancement controls
Adding more advanced visual controls to Enscape would provide greater control over the final image without requiring additional post-processing software.
In particular, advanced controls for:
Sharpening
Contrast
Color grading/correction
Global illumination
Exposure and lighting
Image enhancement
would be very useful for professional architectural visualization workflows.
Overall Feedback
We are genuinely interested in making Enscape our primary visualization solution, which is why we have already moved our workflow from Lumion and currently have 13 licenses in use.
If these workflow and functionality issues are addressed, particularly the Revit rendering workflow, Chaos Cloud panorama experience, direct Cloud uploading, and panorama performance, we see significant potential to expand our Enscape usage and licenses across the company.
We would appreciate it if the Chaos team could confirm whether these are known issues, planned improvements, or if there are recommended workarounds.
We would also be happy to provide additional information, screen recordings, or example projects if that would help your team reproduce and investigate these issues.
Thank you for your support, and we look forward to seeing Enscape continue to improve.
Ahmed Khalil
Ducon Industries FZCO
