Hey ![]()
im rendering 360 spehrical camera with noise target of 2 .
its all work well but when i get to 3.8% some weird dots apears and then the percentages stop and start to risei attached the screen shot.
(when i render in region it ok)
For one thing, don’t use the CoronaCameraMod, it’s outdated. Use an actual CoronaCamera
The CameraMod was there for when back in Corona 2, there wasn’t a dedicated Corona Camera.
What is that dark square in the middle of the render? Is it a shadow of some plane with exotic material applied to it? It seems that firefiles appears only on that shadow, so first thing i would do, is to identify what causing it.
Thanks TomG
i just changed the camera to the regual camera and test it
Are those tree shadows from a geometric trees, or from planes with opacity maps? Do you suspect what can cause those dark rectangles to appear? Maybe there is some non renderable helper objects in your scene? Did you try to render from camera with regular perspective to see if those issues appears in them too?
Also, maybe you’re using enviroment image wrapped on cylinder or sphere?
yes its envimoent sphere
but i test it on regular camera without the 360 and everything is fine.
now im trying to change the camera To the corona camera and its seems fine.
im now check it on another view.
Make sure that your background material is correctly set up. https://coronarenderer.freshdesk.com/support/solutions/articles/5000515605-how-to-create-background-material-in-corona-
