Is there any way to make a 360 render/panorana in Corona?
Baking a reflective sphere doesn’t seem to work.
Add a CoronaCameraMod modifier to an existing camera. Check the Project type Override and choose Spherical or Cylindrical. You can also enable the Spherical VR mod, if you were aiming for VR output. Hope this helps!
The tutorial on it:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000515644-how-to-make-panoramic-renders-in-corona-
EDIT - didn’t check the forum board this belonged to first, apologies, was just reading from New Posts
This may not yet be in C4D.
Actually, it is very similar for C4D ![]()
Just add Corona Camera tag to camera (or create camera using Plugins->Corona->Create Camera), check Override projection and select Spherical or Cylindrical.
Yes, works.
Any tips on what ratio the output image should be? 1:1?
Also, anyone implemented this with Google Cardboard yet?
spherical, ratio 2:1
Thanks!
