I have created a panorama for cardboard - pushed it to the cloud.
Opening the panorama on a computer it works as aspected. Opening it on a iPhone I can only turn left and right (when the cardboard function is off). Not up and down.
As I remember this, normally the view was a lot more “free handed” - meaning turning the phone around your direction where you are looking also changed.
Starting the cardboard function, the view is not showing correctly
I also tried to open some views made before the v2.5 release. They have the same issue.
Am I missing something or is this a bug?
@Arnbjerg , Apple has limited Accelerometer and Gyroscope access in Safari on iOS 12.2 due to privacy reasons. To fully use the panoramas with the latest version of iOS again, please do the following:
On your iPhone, go into Settings > Safari > Privacy & Security and enable “Motion & Orientation Access” accordingly:
](https://forum.enscape3d.com/wcf/index.php?attachment/7292-pasted-from-clipboard-png/)
Please kindly let me know in case this procedure doesn’t help!
I can’t load cloud panorama on my iPhone.
There’s seems to be some maintenance going on since I was able to load the panorama yesterday but phone gyro motion didn’t work. Now I can’t even load the panorama. The “loading wheel” was rotating for 15 minutes now. I’m loading Enscape Demo panorama: http://panorama.enscape3d.com/view/bx16etcm/
Sorry to hear that; could you kindly elaborate on that a bit further? What is missing?
@McRyach , sorry to hear about that. Can you load our panoramas again, or do you still experience the “loading wheel” problem. Also, did you try the short guide above to help with the gyroscope? Does it not help at all?
Thanks a lot in advance.
@Demian_Gutberlet I was able to start the panorama on my phone. But VR mode still doesn’t work. I’ve enabled “Motion an Orientation Access” for Safari in iPhone settings, but gyro still doesn’t work in panorama.endcape3d.com Also when I switch to 3D mode camera is rotated 90 degrees and doesn’t react on camera position or scrolling through the screen.
@Demian_Gutberlet
It sucks because you need to tell clients or stakeholders to setup their mobiles correctly to get the full experience.
Even though it is just a little thing, it is just to complicated to explain every time. Also for Client to share internally this feature.
But to make it bit more useful again, it should be is possible to look up and down just using your fingers.
@McRyach
The cardboard function works for me when “Motion an Orientation Access” is enabled but I had to reload the page after the enabling
Could you please also make sure to, as @Arnbjerg mentioned, reload the panorama after the setting has been activated? And please also try to, if you haven’t already, re-export the panorama through our latest release if the reloading does not help at all.
@Arnbjerg , I’m sorry about this inconvenience and I understand that this can be frustrating, but it’s sadly not possible for us to circumvent this new restriction by Apple. I’ll forward your wish to allow looking up and down with the fingers as well.
Thanks!
@Demian_Gutberlet Thank you. Updating Enscape to 2.5 resolved my issue. You can tell which version was used to upload the panorama to the cloud
by http address. Old web panorama was starting as panorama.enscape3d.com while the new one should start as api2.enscape3d.com
Once again thank you ?? .
It looks like enabling motion & orientation has no effect unless the site you’re viewing is seen by the browser as being secure.
If you add “https://” to the start of older panoramas (and change the motion & orientation setting) they’ll work.
According to the W3C we might be getting the option to ask our customers for motion sensor permissions on IOS… soon™
https://github.com/w3c/deviceorientation/issues/57
Cheers
Stefan
