Parallel projection + displacement
My renderings were stopping midway during ‘Building light cache’ phase whenever I tried to render an orthogonal view such as plan or front. After pulling my hair (almost all of it …) I figured out the issue:
Any vertical surface (projecting as a line) where a displaced material has been applied freezes the rendering. I cant stop it either and the only solution is to kill rhino and in a couple of occasions reboot the system.
Attached is an example. Needless to say that this is urgent.
parallel.zip (286 KB)
We are currently investigating this with the developers and this seems to be a bug with legacy ASGVIS plugins.
Please note that if you change the displacement ‘Mode / Map’ parameter to ‘2D Displacement’ the issue does not occur.
Once we have further feedback regarding this issue, we will make sure to post it here.
Thanks for the tip Georgi. I know that you and I talked about this during our TeamViewer session but I wanted to let other users know about the problem in case they have ‘mystery’ freezes while rendering an orthogonal view.
