Parameter Number input in Enscape Settings
I think slide-bar in settings so useful when we change the parameter in material for testing. But sometimes, like when loaded skybox from bigger HDR file, rotation setting has been lagging while drag mouse in slide-bar.
I think to apply input number parameter feature like older version can fix this problem.
@prg.tojei_1 Thank you for your feedback. I’ve forwarded your request to our developers.
@prg.tojei_1 Have you tried the preview version yet? It does not give you back the number input, but the rotation slider should work much faster.
I have tried Enscape-Setup-2.1.2.564-ga01813f, the rotation slider work much faster as you said. The old version I use was lagged when I rotate the huge HDRI.
However, I like the parameter input combined with the slider is useful. Please add this to the new preview version.
