Parity with Global Switches from CPU
Hi Team
It would be great if we could get similar settings in the GPU Global Switches, that we have in the CPU Global Switches
For example sometimes for projects, in addition to regular rendering, we do stylized renders, and with CPU, we switch of shadows, glossy effects etc. With GPU, we cant currently do that.
Hi @Morne
Do you guys use the new material override system in 5.2 ?
It should be able to achieve similar results, let me know if this is helpful to your workflow
And for Look-dev there are useful debug shading modes in the frame buffer, which I use all the time.
About the switches, many of these are very old and date back to V-Ray 2 ,list to me the ones that you are interested to use. I will check with the developers how hard these are to support on GPU
Best,
Muhammed
We need all of these as well as combination of them:
Shadows OFF
Glossy Effects OFF
Textures OFF
We use it together with multiple simultaneous VRayToon Environment Effects, as well as the VRayToon Render Element
Thanks Morne, I will discuss with the team to see what could be done about it
Best,
Muhammed
