Hey guys, I have prob which I thought was gone.
I have a character which is rigged and have to be posed for stills. When I try to set up my scene and use interactive renderer it stucks in a loop between parsing scene and rendering initial pass.
Can somebody tell me how to avoid that without kicking the rig?
After a bit of digging, there’s is definitely a problem with the characters rigging. The cause of this problem is the joint “L_Hip_int”, as soon as this is deleted the IR starts as normal. I’m no rigger so I can’t give a technical reason why it’s being a b*tch. Perhaps it can be replaced…???
There was a similar problem already with the default Male character from the C4D asset library, but I’m not sure it was solved. Let me dig a bit into the forums…
