particle flickering
Hi, this mighht be a phoenix issue (or a combo) but i’m getting some strange flickering in my phoenix setup. I’ve attached a mov showing the flicker.
The setup is 2 particle shaders firing at each other and meeting in the middle. It seeme to me to only affect the red particles but that could be a red herring, infact it looks like the 2 systems sharing the same 3d space and its choosing which one to render infront randomly. I’m not using gi.
Has anyone seen this behavior before?
WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
I’m going to try reducing the Volume Light Cache Speedup on both the particle shaders & see if that helps.
EDIT: It did not. same flickering as before.
Does setting a small “Secondary Ray Bias” (Render Setup>V-Ray>Global Switches) value (i.e. 0,001) make a difference? If not, do send the scene so we can take a look.
I’ll give it a try, thanks.
