Particle Flow excluded from Toon?
Is there anyway to exclude a PF Source from Vray toon? I can’t seem to get my snow flakes to be normal. Any ideas or is this a separate pass issue?
Does it work if you use the Exclude option of VRayToon?
Exclude works on other objects in the scene, just not the PF Source.
Hmm, I see; it is because the Particle Flow source is not the object that actually gets rendered in the end - Particle Flow creates some render-time objects that provide the actual geometry, while the source object itself is not renderable.
You can try it the other way round - switch the VRayToon list to Include mode and include everything in the scene except for the Particle Flow object. Otherwise you can just composite the snow afterwards.
did it work?
