I’m trying to get color from a texture to change the vertex color of the particles.
As you can see it’s working in scanline render but renders black particles in corona.
As vertex color is supposed to work in corona, I’m wondering if it’s a bug or if the particle flow support in Corona is not complete for the moment.
Thanks for showing me a window I have never seen before (data operator). It looks unsupported, but I am not 100% sure. In fact, I am not even 10% sure. Ondra should be able to answer soon.
ok, I looked at it, and what it does is impossible to do with instancing. I could put in a switch to disable instancing for particle flow, in case this is very important, otherwise, this will remain an unsupported feature
ok I was trying to replicate how multiscatter or forest works, so instancing IS important
I think it would be a good feature to add to corona scatter (get color from distribution surface).
We can add variation with multimap but it’s too random, using a map produces more realistic results.
