particle instancing a Multi material shape
I’m trying to do a particle instance using a shape that has multiple materials assigned.
I can render it perfect, but if I create a particle instancer with these objects only one of the shaders is assigned to the whole shape (all the skin shaders are replaced by the eyelashes shader)
Hello there,
I have looked into this issue and it seems that the only material that is being instanced is the last applied one.
I have logged an issue into our system for our developers to have further look into it. This is the internal bug tracker ID number you can check it with: VMAYA-10126.
Kind Regards,
Dimitrina
Thnkx Dimitrina
