Particles color with alembic proxy
Hi
I load .abc from Houdini.
When i load particles with same colors value.
Vray render particles color fine.
But when the color attributes is different on each particles.
They are all render black.
Any help much appreciated
lucas
Which texture are you using to access the particle color?
I use vertex color.
I have found the solution.
In some case, color attribut in houdini is named Cd Cd Cd instead of Cd Cd Cd**.**
There is no visual difference in houdini, but it seams to be important for the alembic export.
Regards
I have an other question about alembic import and particles.
Is it possible to import the particle size.
I tried psize for attribut name without succes.
regards lucas
See here:
http://forums.chaosgroup.com/showthread.php?80634-Random-particle-size-with-VrayProxy-and-Alembic&p=637911#post637911
Sorry, I should have seen this post.
thanks
