Particles - Scene bounding box is too large
when I render in Cinema 4D Particles, the error message “Scene bounding box is too large, some shading artifacts may occur” appears.
In addition, the artifacts mentioned are also produced.
Scene scaling etc. is fine.
This error occurs as soon as the first particles reach the end of their lifetime and “disappear”. Does anyone know if there is a solution for this case?
The particle system is currently unusable :frowning:
Corona 3 HF 2
Cinema R20
Additional Bug:
in Single Frame Mode all Particles visible in Viewport are also visible in the render.
When Rendering the whole Animation, a lot of particles are missing in the render.
Hello twcg and thanks for your report.
If it wouldn’t be too much work for you, could you create a simple scene for us where we would be able to reproduce the issue? Thanks!
