same as materials but for objects then when you are in walking mode one can pass thru objects like closed doors and furniture.
Hi @Fernando_Lino , thank you for your feedback. In which situation would it benefit you? Walkthrough in VR when you’re not that used to the navigation/movement or do you have some other situations on your mind?
Thank you in advance!
the intention is showing the building and don’t worry about getting stuck with the furniture when you are walking around and passing thru doors when they are closed if you set it up that way…so you don’t have to switch between walk and fly during your walkthrough.
I think I requested this some time ago…with this feature and the option to export as exe file walkthrough only would be great for clients. and also a material to setup limits (invisible) .
Thanks,
fernando
@Fernando_Lino Thanks for catching up on this. It’s still on our agenda!
Yes please! like a Colission element or Invisible material to put boundaries for the clients,
Thanks in advance!
Best,
Julio
great request, it have been requested quite a lot since the launch
