Patchy Grass in render
Good evening.
I have a texture issue and it renders tiled or patchy.
The preview is fine but the final render is patchy… any reason why.
Corona denoiser being used.
Help Appreciated.
Thank you
Phil
Just guessing, but if the grass is just a material (rather than scattered objects or similar), this could be caused by the Mapping Randomizer producing different results depending on how the normal texture is rotated.
If you would like us to take a closer look, please send a scene (preferably minimal) at https://support.chaos.com/hc/en-us/requests/new
Hello, do you have any updates here? Did you manage to fix it?
