I saw the pattern id node in another forum thread and its what i have been waiting for ![]()
i can only though manage to do it on the scene name and not the name attribute and is there possiblity to get for alembic paths?
Regards Alexis
Hello @LeoYfver , check this example.
TexPatternID.zip (1.23 MB)
As I’ve already written only attribute name “name” is supported for Alembics for now.
So, no, it’s not possible for attribute name “path”, only for attribute name “name”.
sorry for not being clear, was more asking if its going to be possible in the future
edit: thanks for the file. Path seems to work there ![]()
Most important part of this is that it’s matching the name attributes INSIDE the packed alembics, something you don’t have access to otherwise
> Working with “path” on alembics here too
Not on top of the Alembic packed primitive “path” attribute, but on the “name” inside packed. glacierise may share some screenshot maybe.
Yes this works but you can do that in many other ways, while you can only access the name inside the packed alembic using the patternid ![]()
Btw, @glacierise will talk about this feature at https://www.chaosgroup.com/24-hours-chaos#shows (Show 10 Sofia).
OK, that clears it up.
The example file from @chakarov was using the “path” attribute also, that’s why you saying the “path” attribute didn’t work left me scratching my head…
For a while the name attribute wasn’t working…but i was using the wrong houdini that had an older VFH version ![]()
With the correct VFH, yes the “name” attribute goes through the packed alembics and get fetched by the patternID node, nice.
Absolutely, great stuff making it possible to manage the alembics! Will talk about it tonight, and will do a writeup too ![]()
Hey Hristo did you share the scene of your presentation or write up how you manage the data coming from OSM and render the alembics, etc? Curious thanks!
Also the example provided - It seems that this doesn’t work on the GPU, can this be added, please.
The presentation is here: https://youtu.be/KAfgnG11gtI?t=6114 but I don’t seem to have the scene, sorry. Check out the video and do ask if something needs clarifying.
Cool - thanks.
I’m repeating the question so it doesn’t get lost
Can we make this technique work on the GPU as well, please? Thanks!, Right now with the latest Vray 5.0.50 isn’t working.
Good to know - we’re still quite early in our GPU tests. That’s an important feature to be supported.
Friendly bump on this, thanks.
Any word on this?
There are no plans to make this work on GPU for now.
Can this be added to work on CUDA please? - This is super useful for the alembic workflow.
