I have a problem that the sun / shadows causes some patterns on some faces.
Is the a way to minimize this? it helps if i rotate the sun, but then it shows up on other faces.
Jorgensen
… hi Jorgensen - the same “striped” effect here
so no solution right now i guess?
@Jorgensen_dk , this is a known issue I’m afraid. Sometimes it helps to downsize the project, for example, if you have a large ground plane, try reducing the size of it as much as possible to see if this may help with the “stripes”.
