PC Configuration Opinions (Ryzen 5 3600)
Today I asked an assistant in computer store to advise me a PC build configuration for CPU rendering of architecture exteriors/interiors in Cinema 4D+Corona. My budget is 1000€ and we ended up at this configuration (see below). Do you find it reasonable in relation to power/cost or would you change some of it to get more performance for the same price or same performance for less price? Or is there something completely wrong?
AMD RYZEN 5 3600
208€
RAM: HyperX 64GB KIT DDR4 2933MHz CL17 Fury Black Series
332€
→ I checked other stores and found some for the same price but with higher specs, such as: Crucial Ballistix Sport LT Grey 64GB (4x16GB) DDR4 3200 CL16
Would be worth buying this one or is there no difference between these?
Water Cooling: Cooler Master MasterLiquid Lite 240
65€
→ I was advised to pick water cooling instead of air
Motherboard: MSI B450 TOMAHAWK
108€
Graphic Card: MSI Radeon RX 560 AERO ITX 4G OC
117€
→ I asked for some cheaper one since I think I don’t need it that much. Is is alright?
Power Supply: SilverStone Strider Essential 80Plus ST60F-ES230 600W
46€
HDD WD Blue 1TB
46€
SSD ADATA XPG SX6000 Pro SSD 256GB
46€
Case: EVOLVEO Ray 2
38€
Thank you for any helpful reply.
