Since I installed my new ryzen 3950x in my existing build I had several Windows freeze while rendering and opening Chrome. It completely freezes the computer and I have to press the reset button.
It doesn’t happen often, but I’m concerned.
Do you see anything out of the normal in the attached measurements by ryzen master?
Thanks!
I updated the BIOS before installing the new chip. It was actually required for my asrock motherboard if I wanted to install the 3950x.
Drivers? For other hardware you mean?
I don’t think I updated the chipset drivers, no. I’ll take a look at this.
I had a similar issue recently with 2 different machines - random freezes, except sometimes the mouse would still work. Would happen under load & whilst idle. In the end, I reformatted one of the machines (2990wx) and slowly added my software back on 1 at a time and (so far) all seems fine. The other machine I simply did a Windows update - I think that’s probably what caused both the problems. So in other words, if that sounds like the problem your facing, check you’re on the latest Windows version. Good luck!
