Pcik object to slate material editor crash
after updating to latest VRay, I got crash after picking object to material editor. Happen always and multiple times with different objects. Never happen to me before so I think newest vray cause this. Is there something I can try? Thank you.
So far we’ve found an issue in case your materials are using the Max NormalBump map - it is known to cause issues and should be avoided. The stable nightly builds have fixes for that - if you could try to install a recent nightly (f.e here Chaos).
Yavor
Yes, that was it. Thank you,
