Peace of Mind
Peace of Mind
Part of my imagination
which causes positive emotions
soft: 3D max Corona render 8
artstation : https://www.artstation.com/irakli
Behance : https://www.behance.net/shubashike06cd
Instagram : https://www.instagram.com/shuba_cgart/
Fantastic mood !
thanks my friend
<3 It means a lot to me
Corona 8 It is a faster and more flexible engine
I am very satisfied
One frame 30 minutes
30 minutes per frame with all this vegetation seems incredible to me. May I ask what are your computer specs please ?
I am also surprised
procesor Intel Core i9-9900K
A new discovery
The result of my observations and experiments
Rendering speed does not depend only on the processor
It even depends on the RAM
It only depends on RAM when you run out of RAM - more RAM when you weren’t running out of RAM will make no difference to render speed.
TomG yes
I thought about it too
But when I increased the RAM
I rendered the same scene 20 minutes faster
I was surprised
Then you must have been low on memory before :smiley: More RAM is of no benefit if you weren’t already hitting the limit (which includes other applications using the RAM of course).
(or there were other changes - a Windows update or Corona update handling thread scheduling on a newer CPU, or other improvements in Corona if one render done on one version and the next on an updated version, and so on)
TomG yes but
I only increased the RAM
I have 64 - it became 128 RAM
Everything else is the same
As I noted previously, unless you were at or close to exceeding that 64 GB, then adding more RAM would not increase or change render speeds at all - I keep emphasizing that point not to argue, but because I would not want any user going out and buying RAM and expecting a speed increase if their scenes already comfortably fit in RAM, as they won’t get a speed increase and will have spent money on nothing. “Spare” RAM that is more than you need adds nothing to render speeds, quality, etc. so in this case, your system must have been using up the full 64GB of RAM (or something else has changed, perhaps something you weren’t even aware of).
TomG yes you are right
I am happy with the speed of Corona 8
Don’t be a party pooper Tom, if people want to have placebo - let them have it :]
Nice renders, by the way!
Hahahaha! I am actually sure he HAS seen a speed up, but also sure it wasn’t RAM (unless it was running out) :smiley: I will put on my party hat and join in though!
BTW Marcin made a good point while we were chatting - while more RAM doesn’t help in and of itself, if your system was not set up with the correct number of memory sticks, then adding another might help by letting the memory switch to dual channel mode, e.g. if you had one 64 GB stick and added a second. Then it isn’t the extra RAM that helps as such, it’s that the memory is now configured properly for how the motherboard and CPU are intended to work. In case it helps :smiley:
Very interesting conversation, I didn’t know the RAM could slow down a render, I only thought that could limit the weight of the scene (textures, number of polygons etc).
At the office, I work with a I9 10900X, 32gb RAM and a RTX 6000. When I work on an interior scene with corona everything is fine, the IR is quite fast. But I noticed that, when I add more than 4 or 5 trees (even with the chaos scatter) everything slows down and that’s a pain to work with (I barely can see what I am doing). Do you think it might be an issue with the RAM or is the 10900x too limited ?
Also, I’m waiting the release of the new 7950x to buy a new personnal computer, do you have any advices about what components should I buy ? (what kind of RAM, CPU etc)
And last but not least, I’ve been told that the 7950x could be, more or less, as good as a threadripper 3970x (but cheaper of course). Does the corona team have some informations about this ?
Sorry for all these questions, and thanks in advance for your answers !
Before we start conspiration theories about RAM speeding up rendering because of my chat with Tom, I would like to suggest a basic fact check:
If you run the Corona Benchmark (Corona Benchmark | Chaos) or some other CPU benchmark and the scores for your CPU are the same or close to what other users with the same hardware are getting - congratulations! There is no need to worry at all, and everything is working fine!
If you are getting a significantly lower score (e.g. 50% of the expected performance), then something is wrong, but it does not necessarily have to be RAM. You would need to troubleshoot. Forum users can help here in the Hardware section, but it’s probably best to involve an “IT guy”.
When rendering a simple scene (i.e. without trees or other heavy geometry with lots of materials) it is expected that both production rendering and IR will be super fast.
The more complex your scene gets (more objects, heavy geometry, more textures, complex effects like reflections, translucency, opacity on leaves, etc) - the slower your rendering will become. This is natural and expected.
If a scene slows down to “pain to work with” level after adding 4-5 trees, I would say something is wrong with the scene. Feel free to start a support ticket and include your scene. Our team will look into it: https://support.chaos.com/hc/en-us/requests/new
