Perforated material issues with Project
We are working on a project in Revit. we built the model and assigned the material in vray for Revit. When we brought the scene to Project Lavina, everything is fine except the perforated metal, which shown as solid metal. The perforated metal we used is straight from vray default library. Can someone help us on that issue? Much appreciated! Attached link is the scene we exported from Revit.
Here is my email, dwang@elsarch.com.
Hello Danwei,
You need to set the opacity mode of the perforated metal to Clip, as that’s the currently supported mode in Lavina (documentation link for reference).
Either set the mode from the Asset Editor UI to Clip, or adjust it in the vrscene file (opacity_mode=1).
Best,
Ana
Hi Ana, thank you for your support, problem solved
You are always welcome!
