perforated metal
I need to create a perforated metal panel, (metal panel with holes) I followed the directions at
http://vray.info/entry.asp?entryID=91
but couldn’t get it to work. I used the Matte/Shadow as the Vraymatwrapper as it’s base material, but the holes would draw in the color of the environment. I need to be able to see through the mtl, into the scene. . .help.
make sure and set the ior to 1.0
those directions are redundant now. In the latest versions you only have to check the affect alpha option in a regular VRay material.
:smile:
Sweet. . .thanks
why not use Vraydisplacement to do that.
:smile:
