i am sure here was a post with the same issue I currently have but I cant find
my dual i7 e5520 uses 50% of CPU power only
-bios hyperthreading is on
-bios “use all CPU” is on
-vray numthreads are 0
-Mental ray, Maxwell and others use 100% but vray not
if i remember right there is a bios CPU setting to disable but wich ?
thats realy odd
I start up max and test a teapot file = 50% cpu usage for LC and IRR but 100% for render
I enable “show calc. phase” LC +IRR and I have 25% during GI and 100% in render ?
If you use the “show calc. phase” option for large images, make sure you have the bitmap pager disabled, otherwise 3ds Max will attempt to page the frame buffer in and out of RAM, which will degrade performance greatly (since the light cache jumps all over the image).
