PF Hoe
Has anybody used PF Hoe camera tracking software, thinks it’s the baby brother of PF Track. Whats it like, any good? its priced at £60 i think so was just wondering what you actually got for the small price tag.
cheers chaps
steve
I remember seeing a very good comment on it in 3DWorld mag, hold on a sec and I’ll look up what they say..
2 mins later…
“With fast and robust auto-tracking, PfHoe is gr8 value for money and ideal for its target audience of aspiring digital filmmakers and independent artists. Rating 9 of out 10.”
imho, for £60 you cant really go wrong,
hope that helps,
Tom
I believe it’s only ‘fully automatic’ tracking. Syntheyes is only a bit more and is much more robust, also Pixel Corps makes an SD-only version of Boujou that works great. Both are around $350 US.
I have both… and both work equally well. Sometimes one will work better than the other on a specific shot, but without trying to examine all the subpixel tracks and what’s going on I couldn’t tell you why this is.
icarus is i found was great
It was icarus that i originally set out to find but you just cant get it anywhere. Is icarus limited as to what footage etc it can use, i know the PF Hoe spftware you’re limited to 720x576.
I tried syntheyes absolute yonks ago, must have been not long after it first came out, it is very good, but i always had trouble getting the scene to export out of syntheyes and in to max at the correct scale, even after checking settings in both apps.
http://files.filefront.com/Icarus\_209/;3922266;;/fileinfo.html :wink:
some other useful links here http://forums.cgsociety.org/showthread.php?t=56175&highlight=heard+programme+called+Icarus
cheers rerender, i owe you one :wink: so it looks like icarus became PF Track\PF Match\PH Hoe then.
I’m gonna have a play with icarus and the demo of pf hoe see how they compare.
steve
Check out the newest version of Syntheyes…major, major improvements!!! Most of which came from the users!!!
