PFlow and Shape Instance with Chaos Asset
We are studying different configurations of assets using the PFlow with Shape Instance. We populate a RGB base image with different assets employing a grid like arrangement. When we use a Chaos asset like (Ginkgo biloba 001_001 or other), it renders as a trunk and envelope as opposed to a trunk, branches and leaves. We have triple checked the material assignments, and asset locations.
This is a workflow that we have used in the past with proxy’s generated outside of the Chaos ecosystem. Do we need to develop another workflow using “Scatter” or am I missing a check box?
Thank you
Hope
PFlow uses only the viewport preview of the proxies; there’s an ancient thread about it here. Try setting the tree proxy’s preview type to “Show whole mesh”. This way, however, your viewport performance will certainly suffer.
I suggest you look into ChaosScatter, since it’s designed for work like this.
Dear Hermit_Crab,
Fantastic and Thank you! I was reluctant to remake the ‘rgb planting bed maps’ as grayscale for use with scatter. We will budget time for that. Thank you for the assistance.
Sincerely,
Hope
