Pflow Frost water drops rendering funky - halp
So I’ve been trying to get the water drop on a bottle shot down for a while, and while I’m semi-happy with my current pflow setup my drops are rendering funky.
The big ‘drips’ are rendering solid white, where as my little ‘drops’ are rendering *almost* as they should.
None of my drops are getting any transparency in the alpha channel. I am using my normal water shader and have tried 4 different water shaders from VMMP and my personal library and pretty much get the same results.
No drops produce transparency in the alpha which leads me to believe none of them are refracting properly, correct?
I am lighting with just a domelight/ hdr. Tried plugging same hdr into enviro slot for reflect/refract.
Can anyone help?
coffee_14v3.zip (6.68 MB)
2 Problems
1) Your particles are still rendering inside the frost mesh, just hide particle systems in the display panel
2) You have no alpha transparency because the refraction’s affect channels is set to color only in your material.
Hi Raven,
Thanks for taking a look! What do you mean by hide the particle systems in the display panel? You mean in Pflow or Frost display panel?
All my display settings in Particle View are set to display none.
Display settings do not affect the render, so you need to hide the particle system. In your normal max viewport, Select PF Source 001 → right click → hide selected. or go to the display panel and hide all particle systems.
You can also turn off the render operator in pflow. in the Pflow Particle View just turn off the Render 001 (geometry) in PF Source 001.
BEAUTIFUL thank you so much Raven!!!
