PG HDRi's
Hello everyone. I have started using HDRi maps for environmental lighting with Corona. I have most of the Peter Guthrie maps and have used them often with Vray for C4D. I am noticing that an intensity of 1 is far too much for my interior scenes as everything quickly becomes burned out. I could use them with Vray at 1:1 with no problem. Any suggestion for finding a reasonable emission intensity for use with Corona? I would imagine others have used these same HDRi’s successfully and may be able to give me some pointers. Thanks, Kevin
No idea which which version you are using, new updated version 1.1 are more polished.
try exposure -4 or -6… depends, it will work fine.
hi iacdxb - thanks for the reply. I am using the latest build. Is it recommended that you lower the exposure value or the emission intensity? I’ll give your settings a try. Thanks again!
Hi, you just have to put the HDRI in the diffuse layer. Not in a light material.
Then i usually lower the exposure between -5 to -1 depends of the HDRI.
it was in diffuse. you can give try in other channels.
Yes, and reduce exposure.
I thought the new way was to use a light material as per this video:
When I do it is way overexposed. Peter Guthrie’s maps all the only ones that behave this way (at least of the maps I own).
I guess what I’m asking is there a way to calibrate the HDRi so that I know I am getting accurate output from the map. Sure I a can turn it up or down, but is it physically correct?
See this… may be helpful.
