Pheonix and Corona Rendering Issues
I’ve been working with this waves simulation using Pheonix and Corona but each time I use the interactive render I get this white screen, and in order to fix it I need to move the camera slightly in any direction which resets the interactive render and then all works fine.
The problem is when I start the final render, as there is no way to update it I get stuck with this white screen therefore I can’t create a final image.
I would appreciate it if anyone can help out with this,
Thanks!
Hi, can you please share a scene of the fluid simulation + your camera (you can remove/delete everything else)?
