pheonix fd - 3ds max
Guys,
Have a few things here I need a little guidance on.
1. I have a smoke sim that I want to create a preview animation in 3ds max. But its not capturing anything from the sim
2. I tried to save out a preview from within GPU preview rollout in PheonixFDFire sim but that tells me to enable GPU preview even though it is enabled??
3. This is all for a an assignment where we have to go back to an old project and add steam coming from a kettle. Is it possible to render out just the steam as a pass and then composite that with single scene still to make a 5 second animation?
Cheers
Michael
1. not quite sure, but as i remember this is a nitrous related problem, try to switch to d3d
2. sounds like a bug, we will try to reproduce it
3. yes, add the atmosphere render element
The in-viewport GPU preview cannot save images yet - we will add this function in the near future. You need to enable the classic GPU preview that works in a viewport of its own - from the viewport menu choose Extended Viewports → PhoenixFD GPU Preview.
Hi Guys,
Thanks for the reply’s.
On response to Question 3 saying that I can use atmosphere render element. I suppose that still means that I must render a beauty pass? I am wondering if there is a way I just render smoke volume. And then just use one still image of scene and animate the steam on top. Trying the same time with render as I need about 300 frames on steam sim. I hope I’m making sense.
Michael
Can’t you just use a normal matte object setup? Or just set a fast render material to all other objects and still use the atmosphere element.
I was thinking that but was wondering if there is a way of rendering only what I want. Just want to see how much time can be saved.
I guess I’ll give that I go then.
Thanks.
Michael
The PhoenixFD GPU Preview window is completely black? I tried changing background color to check if that was obscuring smoke but no effect.
Any ideas?
Michael
Hey,
You need to have your simulator selected, and you need lights in the scene in order to see the smoke.
I had lighting already in scene and active as well as sim selected. I see it fine in normal viewport but not in special phoenix viewport. The smoke color also refuses to change even though I have changed it in fire and smoke settings.
I really hope one day I can be the one with answers but for now I say thank you for the help :slight_smile:
Michael
Would it be possible to send to support@chaosgroup.com the scene and one cache file that does not show, so we can investigate this?
Done!
Michael
