Phoenix 2.0 Maya BETA Error: Could not obtain simulation license.
I just installed the Phoenix Maya Beta and build the scene like in the video tutorial.
When I hit the sim button noting happens and in the script editor this msg shows up:
// PhoenixFD: Simulation output will be saved to ‘C:\Users\Rico\Documents\maya\projects\default\data\untitled_Phoenix2_frames\@transform1@PhoenixFDSimulator1’. //
currentTime 1 ;
// Error: Could not obtain simulation license. //
// Simulation stopped. //
How do I get a licence?
cheers
Rico
You will need to update your dongle with a beta license - the process is pretty much the same as for adding a V-Ray license - you just need to send us the .wbc file from your license server.
Okay
Sorry … I can’t find a .wbc file on my system.
More help would be very nice.
Rico
sorry .. .found it in the vray4maya docs how to generate the .wbc file
I don’t suppose you could say which document/page this is, I’m trying to find it as well now.
:slight_smile:
Doh, just found it:
install_vrayformaya_windows.pdf
page 12
Apologies, for some reason I cannot edit my posts in this part of the forum/thread (?).
I’m trying to run the getstatus wizard but it’s not working for me at all.
I’m using google chrome, and it says that javascript is enabled.
i think you can export the wbc file via the WkConfig tool too. worked on my mac, pretty sure you can do it with a pc too.
Hey Bard,
I’m not seeing a WkConfig tool in my directories unfortunately.
Sorted now.
And if anyone else has a similar issue, definitely follow this:
try following:
- Start the license server and make sure that the black VL icon appears on the notification area of your Windows task bar.
- Disable completely your Windows firewall and any antivirus software that you might have
- On the same PC open the status web page of the license server: http://localhost:30304/getstatus
- if you still can’t open the license server status web page please send us an email to support@chaosgroup.com with regards to this threads and we will work from there
Hi guys,
I’m trying to make phxfd run, but I get // Error: Could not obtain simulation license. // I got my license, installed it , can see it on the server (its valid till end of June) but still simulation doesn’t run.. :frowning: Server is shared over internet but I’m running vray on same pc and it works.
Any ideas ? thanks,
Jakub
